All I could get done today was cutting the wing trailing edge stringer at BL138 and drilling and mounting the angle iron stringers to the wing cradles. I used two screws at each attachment point. The manual suggests bonding the stringers to the cradle with bondo, but I am not convinced that will be sufficient to withstand the clamping pressures, so screws it was.
