After work and with Cathy's help I finished cutting out the wing cradles. The cradles nearest the fuselage are quite large, and I needed help holding them up while cutting them on the bandsaw. Next I marked the centerline and building lines on the table, and set up the cradles in their approximate position. There's 12.45 inches of height difference at the leading edge between the 25.5 and the 204 building lines. That looks huge in person.
