Finished sanding micro on the right lower sectiion of the HS. Then I applied a skim coat of Evercoat, and began sanding it. Didn't quite finish the first sanding with 36 grit, but the progress I did make was good. I checked for gaps with long level and flashlight, and found no gaps at all. I did find lots of pinholes, though, so there's still lots to do.
