Today I continued on my checklist of things to do before taking the plane to Carrollton. I finished mounting the AOA display to the glareshield, and re-pinned the d-sub connector. Also, I mounted the right elevator control horn to the right elevator, and installed a stud on the rear of the engine to mount a baffle bracket to the rear of the engine. I also deterimed that I'll have to re-make the door seal pump and associated valves, etc. because the leads from the door switch hit the top of the pump. Lots more work.
