After a whole lot of work, some of it spent in a learning curve, I have the two overhead vent/light panels complete. I made them with carbon fiber sheets that I made with six layers of carbon fiber, vacuum formed. To the panels, I mounted two red/white lights with SPDT switches, and two Setinair vents mounted to each panel. I didn't like the way the first set turned out, so scrapped the first attemps and started over. On the second try, I used Eastwood two part clearcoat for the finish. The finish is fine. There is a bit of a weave anomoly in one panel, but I'm going to let that slide. Otherwise all seems fine.
