Jim's Web Site
Date:  12-30-2018
Number of Hours:  6.00
I'm still working every day, but posting remains my weak point. Anyway, I discovered that my kit came four front windows, two each 3/16 and 1/4, but no rear windows. Luckily, Lancair did have what I needed, but not cheap. I've also been working on fitting the cowling. The bottom is pretty well fitted, so top is next. Haven't decided whether to use fasteners for the horizontal joint, or install hinges. That will probably depend on whether I can come up with an acceptable way to hide and secure the front end of the hinge pin. I've also begun fitting the fresh air plenum.
