As usual, not too much time to work today. I decided to add two layers of bid to the inside of the rudder trim inspecion panel to add some stability and to give plenty of thickness to countersink the attaching screws. To do so, I decided to do the layup with the panel still attached to the skin, with release tape on the margins of the skin. After trimming next time, I can place release tape on the panel, then lay the supporting bid on the inside, providing a perfect fit (hopefully).
