Spent some time finishing up removing peel-ply from the vertical stabilizer halves, a job I really do not like. But this may be the last peel-ply to remove, if I'm lucky. After that, I bonded in the sternpost, after first re-checking that the sternpost is centered on the centerline of the fuselage, which it is. I'm not real happy about the fit of the vertical stabilizer relative to the sternpost, but have a plan.
