Jim's Web Site
Date: 5-17-2017
Number of Hours: 2.70
Started work today by adding 2 bid reinforcing on the under side of the avionics shelf extension installed yesterday. Because I bonded the extension to the existing shelf, and to the adjoining motor mount supports, it turned out to be quite well supported, so much so that it does not appear that I will need any supporting ribs. This piece will carry little load. When I get everything mounted, I'll check for deflection and make my final decision then. After that, I put nutplates on the battery box to provide mounting for the hold down bolts, which came in today. Battery box is done. It's not a work of art, by any means. In the production world, I'm sure that what I built would at best be the proof of concept, to be followed by refinements, prototypes, more refinement, then production. I don't have that luxury. Certainly it may be made lighter, stronger and better looking. But what I have will work, and it's not too ugly.
