Jim's Web Site
Date:  4-3-2017
I've known for some time that a main bus is required, but there really is no guidance regarding number of lugs needed. Still don't know how many components of the panel I will have, nor how many of them need their own power. Space is also a concern. So I'm guessing. Not wanting to shell out the big bucks, I decided to make my own bus. I used 1/8 inch thick copper, and set press-fit lugs, coming up with fifteen spots, but knowing that its probably not enough, I made two identical bus bars. Both will connect to the battery lead, then exit through the firewall to the starter contactor and ammeter B-leads. I'm not through with the fabrication, though, in part because I ran out of the studs. Now I've got to decide whether it's worth the effort to add another, avionics bus.
Main bus bar from rear
Top bus bar bolted to firewall carry-through bolt
