Jim's Web Site
Date:  6-16-2016
I took a long time today to get the control rod from the elevator torque tube to the idler measured and cut. Most of that time was figuring out how to get the idler set at 10 degrees to enable measurement. I finally hot glued a wood shim along a vertical line on the idler, and used an angle finder, while making sure that the control stick was vertical and the elevator torque tube was set according to plans. Pics show all rods in place, but most rod ends are just secured with instant glue. Rivets later.
