Yesterday and today I completed placing, reinforcing and fine tuning the elevator stops. This would have been a whole lot easier if I'd done it before bonding the HS to the fuselage. Adjusting was pretty easy. Today I set up the control rods for the elevator, and measured the last rod from the idler to the elevator weldment. Then began to set the rod end into the 1.375 inch aluminum tube. That is until I broke a dril bit off deep into the rod end. That will probably mean trying to find a new rod end, or fabricating one.
