Nose wheel pant spacers cured just fine, so I sanded he rough edges and drilled them out to take #10 screws. Then checked fit on the fork, which was fine. Next I fitted a template for the nose wheel pant bulkhead, cut the bulkhead out of 2 bid honeycomb and installed it, reinforcing with 2 bid. Later in the evening I installed temporarily the bearing blocks and hinges for the elevators. Need to trim the tail of the fuselage to clear the control horn, but that will have to wait till tomorrow.
