Started out placing the four bid flange that helps secure the rear passenger footrest. After that, I continued to fabricate the fuel pump mounting bracket. I think its turning out pretty well, and now is plenty sturdy. Had to notch out the front floorboard a bit to clear the pump. After all that, it dawned on me that the fuel selector that came with the kit is probably not workable, since Lancair decided to go with 1/2 inch fuel lines. The old selector seems to be for a max 3/8 inch lines.
