Jim's Web Site
Date:  7-9-2016
Number of Hours:  3.40
More fabrication of panels today. This project was the elevator push rod cover supports. Not having enough carbon fiber, I used standard fiberglass, two bid per side, with 1/4 inch foam core. Of course, since I can't autoclave these panels, I'll use this process only for non-structural parts only. Using vaccum bagging again, these parts turned out very well.
Under vacuum
Under vacuum
Afture cure
Afture cure
All trimmed up
All trimmed up
