Block sanded the left gear leg fairing that I filled with micro yesterday. That only took 20 minutes. Then I filled pinholes on that side and on the right side with Evercoat 400. That stuff cooks off very quickly. Only five minutes or less of working time, even with reduced catalyst. That's ok, though, once you get used to it.
Also, I sanded the blister on the left access panel, and applied two bid for later filling and sanding later. The blister turned out to look good. Maybe a bit more prominent than absolutely necessary, but that's probably better than a very small blister that could look more like a mistake.
Finally, it seems that the primer is cured enough to wet sand. Looks good.
