Jim's Web Site
Date: 2-10-2016
Number of Hours: 3.00
More pinhole filling, sanding, and finally more primer application. When it was time today to apply the WLS primer, I decided to squeege in the first coat, to help with unidentified pinholes. Well, that worked ok, but it flashed much too quickly, so I had to rush a bit with the subsequent rolled coat. For the squeege coat, I tried doing it without ruducing, but that probably was the wrong decision. Anyway, when all was done, it all did turn out ok, although there are more pinholes. My plan now is to fill those before wet sanding the primer I applied today, in order to minimize sanding into the underlying glaze and micro. We'll see how that goes.
