Jim's Web Site
Date: 1-25-2016
Number of Hours: 2.30
Continued to sand and refine the gear leg fairings. This is really physical work, no doubt. These are complex surfaces to sand, so I feel that if I can achieve a good result here, the less complex surfaces should be easier. Not less physical, though. The access panel on the left side is looking good. In my opinion the fit of the access panels and other intesections tells a lot about the care and attention to detail that really shows the care in construction of the whole airplane. Lots of other factors as well, but bad fit of intersections tells a lot. Not only that, this part, because it is on the underside of the plane, gives me an opportunity to learn and refine the finishing skills. WLS arrived today, so after I'm satisfied with what I'm doing now, I'll move to what amounts to a pin hole filler and guide coat.
