The last few days I've been setting up to set the toe in angle on the main gear. This involves a lot of measuring, leveling and jig making. I also decided to use Loctite 680 retaining compound to fix the axle bracket to the leg while drilling out the bolt holes. Tonight I got it all set up, went through a dry run, then set both wheels in place with Loctite. It's supposed to cure for 24 hours, so I'll see tomorrow how it works.
