Jim's Web Site
Date:  9-18-2015
Number of Hours:  5.00
Since the last post I've finished the rough installation of the wing fairings. This is, as I predicted, a very difficult task. Today I bonded the first piece on, the lower forward right piece. The problem, of course, is getting the fairing/wing joint aligned well. Eventually I quit trying to get the gap exact at this stage, but I did get it close. When I add the ribs that will help, then some body work should fix things up. On the picture below, the visible gap is caused by an irregularity in the wing itself, which does have to be fixed with filler.
