I am making progress on the new aileron, but it's slow. Yesterday I formed the new counterweight tab on the outboard end of the aileron, and today began fitting the aileron to the wing skin. Because I had to make the aileron a bit thicker than the skins were formed at the factory, the pockets built into the lower skin do not fit to the upper skin. The only solution I came up with for that problem is to cut out formed pockets, except for their ends. I'll add a bit to those and shape to fit the upper skin. After the skins are joined, I'll reinforce these areas with carbon.
