Spent most of my shop time today sanding the trailing edges of the aileron and flap to make them even with each other and with the wing tip. Sounds easy, but the trailing edge of the aileron is flox between the upper and lower aileron skins. That is tough stuff. On top of that, my six foot sanding block is two by three inch aluminum tubing, and weighs several pounds. Holding that up while pushing against the trailing edges is an exhausting task. After no small amount of work, and changing the sand paper on the block, the fininshed product is just fine. After that, I made stands to hold the wing for storage while working the fuselage.
