Jim's Web Site
Date:  9-3-2014
Number of Hours:  1.30
Last night's micro release turned out to be less than satisfactory. Apparently just clamping the skin down with the cradle tops was not enough. The result was too much of a gap between the skin and the ribs, so much so that some areas of micro barely contacted the skin, leaving little or no capstrip bonding surface, and way too much micro. So today I had to sand off most of the micro, hog out grooves, and do the process over. This time I placed my aluminum sanding board, two inches by four inches, between the main spar and the 202.5 rib, and added weight, and checked the whole setup with play doh. This produced a good gap of about 1/8 inch, so I went ahead and re-set the micro. I'll check the whole deal again tomorrow a.m.
