The last several days I've been able to work sporadically, but progress continues. I set all the proper bolts, washers and lock nuts required to secure the wing attach bracket, then torqued them to specs. After that, I cut and fit the foam necessary to seal the bolt heads on the inside of the inboard fuel bay, and sealed the whole thing with flox and 2 bid. Today I trimmed the rib reinforcements where they overlapped the ribs, etc., started placing the holes for the fuel probe, and did some final fitting on the skin to rib junctions, in preparation for micro release and capstrip iinstallation.
Wing attach bracket bolts torqued and ready
Wing attach bracket bolts sealed in inboard fuel bay
