Jim's Web Site
Date:  7-17-2014
Number of Hours:  2.50
I'm out of epoxy hardener, so am a bit limited, and had to stop about half way with the main spar flox pad. So yesterday and today I sanded what I could of the flox pad, and began fitting ribs to the upper wing. The epoxy/flox pad is turning out great, though it's tough to sand down the squeeze-out. Next to impossible without a belt sander and 36 grit belts. But the result is pretty near perfect. I sort of hate to start the tedious process of fitting the ribs, but it has to be done. There's just no quick or easy way to do this.
Main spar flox pad, sanded
BL75 inboard rib
BL75 inboard rib
BL 171 forward rib
BL 171 forward rib
