Completed trimming shear web and outboard portion of main spar closeout, then did a micro release on both. Also, since I had the time, I placed three blobs of epoxy/flox on the main spar per manual. This is a bit out of sequence. But I learned with the left wing that it helps when fitting the ribs to have final heights. The main spar epoxy/flox pad will set the relative positions of the two skins, so when I size the ribs, they should be right on the money.
Lower wing skin in place for micro release of shear web and main spar closeout
