Potted in the flap hinge ribs tonight. This required routing out a groove on the phenolic inserts, then prepping the ribs and upper flap skin for bonding. Alll went well, I believe. The only real issue, I believe, is the the ribs are to be parallel to the hinges, which is a bit of a delicate process.
