Yesterday I reinforced the wing leading edge with 2 bid with no problem. That is if a leading edge that has the general shape of a garden snake is ok. It's really not that bad, but it is noticeable when I sight down the front, or put a straight edge on it. There are a couple of high areas that make the whole thing less than a thing of beauty. I've still got to fill the joggle area with micro, and the joggle does extend pretty close to the leading edge, so my plan is to slop over a bit, then try to sand a straight line with a very long sanding board. After that, I can work on the contour. Seems to me that I've seen another builder with this issue, but can't remember where. Any suggestions are welcome.
Today I had little time, so just spent about an hour getting the flap area trailing edge ready for finishing.
