Jim's Web Site
Date: 12-15-2013
Number of Hours: 6.50
Yesterday and today I actually made some pretty good progress. First, I completed and sanded the micro/flox pads for the aileron bellcrank and idler. Next, I cut out and microed in the aileron ribs. Then, with no small amount of fitting, re-fitting, mocking up, measuring, etc., I was able to mount the bellcrank to the BL 145.5 rib, and enlarge the forward rib holes to accomodate the bellcrank movement and the bellcrank to idler tube. Next is to mount the idler. Also, I was able to mount the aileron actuator arm.
Aileron idler micro/flox mounting pad
Aileron ribs
Aileron bellcrank mounted and mocked up.
