Haven't had much time to work on the ES the last couple of days, but I did get back to it a bit today. I'm at the point of building the aileron, with the next step being attaching the aileron spar. But before doing that, I'm double and triple checking all measurements and relationships between the various parts. The manual calls for a different aileron actuating arm than was supplied with the kit, naturally. After checking with Lancair, I'm still not quite sure which part I need. While I'm figuring that out, I'm making sure that when I place the bellcrank and the actuating rod, that all will work out, before attaching the actuating arm, and thus before attaching the spar to the upper skin. So there's a lot of mocking up and measuring to do.
