I'm working in two directions to get the capstrips reinforced. First on the forward side, toward inboard with reinforcement, and next on the aft side, again working inboard on the micro fillets. This way i've always got cured micro fillets to work with. I did finish all preliminary sanding today, and got the micro on the three outboard aft ribs and webs. Next I continued with the reinforcements on the fuel bay ribs, with only three more to go on the forward side. Earlier in the day I began shaping a micro fairing that I roughed in last night. This fairing surrounds the fuel drain valve. This fairing anchors a cotter pin, which will be used to safety wire the valve. Only the eye end of the pin sticks out.
