This morning I microed in the BL 120 aft rib, then started buiding a box to heat the epoxy resin and hardener. I ended up with a 20x20x18 inch box, with two light bulb fixtures. Placed an inexpensive thermometer on the inside of the double door. Late in the afternoon, I installed two forty watt bulbs, and pllugged it in. After a couple of hours, the temp was around 80 degrees. I'm continuing to monitor the temp this evening. Options include any combination of one forty watt, two forty watt, one sixty watt, and one forty and one sixty watt bulbs, just for a start. We'll see.
