Today was fitting the trim tab. I started by drilling the appropriate holes for the screws on the trim tab. Most of the time I spent today was on trimming the lower skin to allow the downward movement on the tab. That was a bit tedious, but eventually I got the tab trimmed enough to allow about 45 degrees of downward travel. Up travel is essentially unlimited, for the hinge is on the upper side.
