Today I microed the hstab counterbalance horn area, up to the leading edge. Also, I decided to wrap a 1 bid layer around the trailing edge of the elevators. My thinking is that because that area is so thin, it may be subject to more movement. As yet, the upper and lower skins are joined only by hysol. I'm just not convinced that delamination is not likely. The trailing edge has to be built up anyway, so I'll just fill it partway with 1 bid, and the rest with micro.
