Jim's Web Site
Date:  7-29-2012
Number of Hours:  2.20
Removed the left skin from the micro release layup, then began working on the rudder trim access panel and laying out the rudder trim tab. I misread the manual, and removed core material from the right skin where the trim tab is, rather than the left side as directed. This should not be a problem, though. I'll just reinforce the right skin with a layup. The only real difference should be the difference in weight, but that will be negligible.
Rudder trim access panel
Rudder trim access panel and trim tab
Left rudder skin trim tab core removed
