Legacy N222BZ
Date:  3-15-2004
Number of Hours:  3.00
Manual Reference:  Sec 9B
Brief Description:  Canopy rollover.
Installed the rollover stiffening IAW the manual Section 9B. A 6 BID layup was applied inside the top of the rollover. The bottom 2 BID is 14" long. The next 2 BID is 12" long and the last is 10"long. 1/4" foam was then bonded on top with runny micro and let cure. Lastly, a 4 UNI layup was applied on top of the foam. The stiffener is now, theoretically, custom fit to the fuselage.
Lots of clamps to hold the rollowver.
Carbon then foam epoxied into rollover.
4-bid carbon will be applied over curved foam.
