Johns Web Site
Date:  4-8-2019
Number of Hours:  7.00
Brief Description:  Wiring Trim Servo
Discovered a couple of months ago that the original builder had wired the Ray Allen Stick Grip to use a relay deck to control the trim servo. It was easier to order the relay deck than to rewire the stick grip. Installed the Relay Deck on the left side bulkhead rib and completed wiring the trim switches and servo feeds to the relay deck. Tested it out with a 9V battery to confirm continuity and that the servo runs in the correct direction; front button for trim down and back button for trim up. Remaining task is to run power from the AP circuit breaker to the relay deck red power lead.
