Johns Web Site
Date:  8-28-2019
Number of Hours:  3.00
Brief Description:  Install Wing Tips
Started installation of wing tip by installing Forward Wing Tip Skin. Encountered problems with lining up the top rear of the forward wing tip skin. Holes are drilled on the bottom attach point but when you have rolled the Forward Wing Tip Skin and clecoed the bottom half it does not line up with the forward skin on top. The problem is cosmetic. The forward skin is held down by my left hand fingers, and you can see if you enlarge the photo that the rear of the left hand foward skin does not line up with its counterpart on the wing. The holes on the bottom were already drilled
