Complete Engine Items X - Rewire left mag ground wire X - Install baffle tie down - Check Dynon D120 Battery Status; it's shutting off when master switch is turned off, it should stay on for 30 seconds X - Run engine to determine fuel flow; tempurature sensors, ect X - Install Brake System X - Install Engine Cowling X - Reconnect Rudder Cables X - Fabricate Airleron Weights X - Install/Checkout ELT X - obtain and install caps for through fire wall holes. X - Install and Wire ELT; one came with the kit but it may not be functional. X - Fix heat muff control cable X - Recut parking brake cable X - Install Pitot, AOA, and Static hoses to back of D100.
- Install seat belts - Run and log a fuel flow test - Cut autopilot servo rods to size, thread and Install AutoPilot servo control rods; Greg suggests we do this at the hangar after we attach the wings - Go over following connections and order/confirm hardware
