Johns Web Site
Date:  8-17-2020
Number of Hours:  4.00
Brief Description:  Faucet Electric Fuel Pump Test - 22 GPH
We did an initial test of the fuel flow and got about 7GPH. There was one tight turn in the connection from the firewall fitting to the gascolator. We removed the hose, changed the direction of the 90 degree fitting on the firewall side, and installed a shorter hose with a less severe bend. The second test filled a quart container in 40 seconds which equals 22.5 GPH.
