We attached the wings using temp bolts on the 5/19 as pictured. On Friday I removed the temp bolts one by one replacing them with the Close Tolerance Bolts. I had some difficulty knocking the left wing bolts in with a rubber mallet, but was able to use a bucking bar. The problem was that the autopilot bracket was in the way. Unfortunately I ordered 12 close tolerance bolts of the same size not realizing that I two outboard bolts on each wing were slightly longer. Awaiting shipment from RANS to finish.
