Johns Web Site
S-19
Trim Servo DB9 Pinou
Confirmed pinouand wire color codes from cockpit to Trim Servo DB9 connector.
Pin# Wire Color
6 WH
9 WH*
3 WH/BL
1 WH/GR
5 WH/OR
* White wires are interchangable. Reverse them if movement is not as desired when depressing up/down switch on G205.
S-19 Home
346
Brakes
Control Surfaces
Lighting
Paperwork
Wing Tip
