Johns Web Site
Date:  3-24-2020
Number of Hours:  1.00
Brief Description:  Transponder Altitude Display
Transponder is displaying an altitude of -100'. Need to research how it recieves this data; suspect it comes from D100 reference altitude for barometric pressure of 29.92.
Update - not to worry, The altitude encoder is a function of the D100 as set to 29.92 per note above. The altitude should display correctly when the transponder/D100 is adjusted during the pitot/static check.
