Rollbar support bracket was not installed during Neal's construction. Had the part powder coated, removed canopy, drilled out rollbar rivets, installed rollbar support bracket, and riveted rollbar to fuselage with cherry pop rivets. Awaiting bolts and tensile nuts to complete the install. Note that the photos are rotated 90'. I'm not sure why that happened but if you simply tilt your head all should come into focus.
