I cut the hole in the trailing edge for the servo arm. I reattached the trim tab and test fit everything. I wired everything up to a 9V battery and tested it. I noticed that that when travelling from full down deflection back to center the gauge shows center. But when moving from full up to center the gauge shows down a bit. I will test again once everything is riveted.
