Brief Description: Finished primer - started assembling stabilizor
The Cortec primer left run marks on most surfaces touching the table. I had to trim this material off with a razor blade. I spent about an hour cleaning up parts to get them ready for reassembly. When starting the reassembly I noticed that a lot of the marks I had made with a Sharpie had been lightened or completely removed by the primer. This made the reassembly take a little longer. Next time I will prime all the parts before any work is started. I drilled the elevator horns and rounded the edges. The stabilizer skeleton is assembled and the A4 rivets were pulled on the front spar.
