Johns Zodiac XL Builder Log
Date:  2-28-2006
Number of Hours:  1.00
Manual Reference:  6-T-6
Brief Description:  Test fit trim servo
I cut the hole in the trailing edge for the servo arm. I reattached the trim tab and test fit everything. I wired everything up to a 9V battery and tested it. I noticed that that when travelling from full down deflection back to center the gauge shows center. But when moving from full up to center the gauge shows down a bit. I will test again once everything is riveted.
Centered
Centered
Full down
Full down
Full up
Full up
