Johns Zodiac XL Builder Log
Zodiac XL
6-T-6
Started on Trim Tab
I laid out the the cut out for the trim tab. Then I drilled out the center rib. With a hole saw I some large holes at both ends. I began cutting and took my time. Once done cutting I trimed the rib and channel. I ended by test fitting everything.
All cut and trimmed
Piano hinge
Nice fit
Zodiac XL Home
