Brief Description: Left engine carb heat, primer, electrical
Finished installing the carb heaters on the remaining carbuators. Reinstalled the carburators on the left engine. Finished the coolant hoses for the carb heat on the left engine. Installed the carb priming system on the left side. Worked on bundling and protecting the wiring going to the engines through the struts.
