Fabricated the brake lines from the master cylinders to the calipers on the floats. Had to redo tu fitting at the master cylinders due to improper assembly from the factory. Transitioned from the Aeroquip to the nylaflo tubing inside the fuselage. Bled the brakes with DOT4 fluid. I had previously changed the o-rings in the caliper to use DOT4 as the Beringer master cylinder were set up for that fluid.
